Diesel Piping Chart
Diesel Piping Chart
Diesel Piping Chart
Dear Experts,
Could someone please share the diesel piping chart that can be used to arrive at pressure drop for various diesel flow rate corresponding to the various schedule pipe sizes. I had seen Carrier piping chart that is prepared for chilled water that have a different density and viscosity. Hence for that frictional and total pressure drops should vary from this ASHRAE or Carrier's chart.
Thanks in advance.
Manukumar
RE: Diesel Piping Chart
If you buy a copy of Crane technical paper 410, you will be able to calculate the pressure drops.
Matt
