Column Minimum Distance - Bridge Substructure
Is there any code indicating the minimum distance of 2 columns for bridge substructure (pile bents or column footing)?
RE: Column Minimum Distance - Bridge Substructure
Do you mean distance between 2 columns? Why would there be such a minimum? Perhaps you can explain why you want to know this.
in terms of being economical in the design :)
Codes don't deal with economy.
