Low Temperature Flange Bolting
Any help and/or advice would be appreciated.
6"-ANSI 300# Flange set @ (-)100oF internal temperature.
Stud bolts have dielectric isolation sleeves (insulating kit).
It is needed to determine if B7 stud bolts are acceptable.
Due to high internal pressure, the strongest material is needed.
RE: Low Temperature Flange Bolting
Steve Jones
Corrosion Management Consultant
http://www.linkedin.com/pub/8/83b/b04
All answers are personal opinions only and are in no way connected with any employer.
