How to add dimensions to a draft with breaks (real dimensions, with less space)
I am doing a CAD draft on Inventor, and I have a part that has 1000 mm lenght. It does not fill the paper. I know how can I break the part, but what about the dimensions? How can I tell the model that I want to reduce 900 mm, lets say, and still have a 1000 mm dimension, with the break on the middle??
thanks in advance
regards,
Hugo
RE: How to add dimensions to a draft with breaks (real dimensions, with less space)
Have you tried it?
It should handle this automagically.
Inventor will be automatically take breaks into account, as long as it's a real break and not sketched.
Its magic... Thats all you need to know :)
