ANSYS - UPGEOM changes the unit but not the magnitude
thread727-278335: Nonlinear Buckling in Ansys Help
Hi all,
I am referring to the above thread as I have the exact same issue.
After running a linear buckling analysis, I wish to perturb the model by 0.1 of the deformation (which I assume to be scaled to max 1 meter) using the following APDL script.
/prep7
upgeom, 0.1 ,1,1,file,rst
cdwrite,db,file,cdb
But when I look at the model in the finite element modeller. It has shrunk by a factor of 1000.
Any ideas?
Hi all,
/prep7
cdwrite,db,file,cdb
Any ideas?
