3 Axis Fanuc Post Modification?
I downloaded the Fanuc 3axis in post from the library but it needs some modifications. I designed a quick part in NX and put tool paths on it and I did the same in Mastercam with similar toolpaths (we have a working post). See the code below. The G100 and G200 lines are subroutines within the control. This is the G100:
O9010(G100)M9
G80G67G40
G91G30Z0M05
G0G17G49G64G90G94G98H0D0F0M1
M99
NX Test:
N0020 G91 G28 Z0.0
:0030 T01 M06
N0040 T02
N0050 G1 G90 X.5 Y-1.8281 Z.5 F20. S3000 M03 M08
N0060 Z.1
N0070 Z0.0 F23.
N0080 X.25
N0090 X-3.25 F25.6
N0100 Y-1.5313
N0110 X.25
N0120 Y-1.2344
N0130 X-3.25
N0140 Y-.9375
N0150 X.25
N0160 Y-.6406
N0170 X-3.25
N0180 Y-.3438
N0190 X.25
N0200 Y-.0469
N0210 X-3.25
N0220 X-3.5 F20.
N0230 Z.1
N0240 Z.5
N0250 M09
The program end looks like this:
N4570 G2 X-3. Y.25 I.25 J0.0
N4580 G1 X-1.5
N4590 X-.5 F20.
N4600 Y.5
N4610 Z-.41
N4620 Z.5
N4630 M09
N4640 M02
Mastercam Test (This is what I need)
(T1 - 1/2 FLAT ENDMILL - H1 - D1 - D0.5000")
(T7 - 3/16 FLAT ENDMILL - H7 - D7 - D0.1875")
(OVERALL MAX - Z2.)
(OVERALL MIN - Z-.5)
N100 G100
N110 T1
N120 M06
N130 G100
N140 (MAX - Z2.)
N150 (MIN - Z0.)
N160 G00 G90 G54 X-3.55 Y-.1251 S3500 M03
N170 G43 H1 Z2. M08 T7
N180 Z.21
N190 G01 Z0. F8.
N200 X.3 F15.
N210 Y-.4501
N220 X-3.3
N230 Y-.775
N240 X.3
N250 Y-1.1
N260 X-3.3
N270 Y-1.4249
N280 X.3
N290 Y-1.7499
N300 X-3.55
N310 G00 Z2.
N320 M09
N330 G100
N340 ()
N600 G00 Z2.
N610 M09
N620 G200
N630 M06 T22
N640 M30
I have looked at the post builder but I could not make it work. Any ideas?
Thank you
John
O9010(G100)M9
G80G67G40
G91G30Z0M05
M99
NX Test:
N0020 G91 G28 Z0.0
:0030 T01 M06
N0040 T02
N0060 Z.1
N0070 Z0.0 F23.
N0080 X.25
N0090 X-3.25 F25.6
N0100 Y-1.5313
N0110 X.25
N0120 Y-1.2344
N0130 X-3.25
N0140 Y-.9375
N0150 X.25
N0160 Y-.6406
N0170 X-3.25
N0180 Y-.3438
N0190 X.25
N0200 Y-.0469
N0210 X-3.25
N0220 X-3.5 F20.
N0230 Z.1
N0240 Z.5
N0250 M09
N4580 G1 X-1.5
N4590 X-.5 F20.
N4600 Y.5
N4610 Z-.41
N4620 Z.5
N4630 M09
N4640 M02
(OVERALL MAX - Z2.)
N100 G100
N110 T1
N120 M06
N130 G100
N140 (MAX - Z2.)
N150 (MIN - Z0.)
N180 Z.21
N190 G01 Z0. F8.
N200 X.3 F15.
N210 Y-.4501
N220 X-3.3
N230 Y-.775
N240 X.3
N250 Y-1.1
N260 X-3.3
N270 Y-1.4249
N280 X.3
N290 Y-1.7499
N300 X-3.55
N310 G00 Z2.
N320 M09
N330 G100
N340 ()
N600 G00 Z2.
N610 M09
N620 G200
N630 M06 T22
N640 M30
Thank you
John
RE: 3 Axis Fanuc Post Modification?
The Documentation is very detailed. The changes your looking for seem fairly simple and you may find other posts in the library that better fit your needs.
the G100 & G200 could be insert from NX or customized into the post. Have you looked at http://community.plm.automation.siemens.com/ or http://community.plm.automation.siemens.com/
there are several tips on Post builder.
John Joyce
N.C. Programming Supervisor
Barnes Aerospace, Windsor CT
NX6, NX7.5 & NX8.5
Vericut7.2.3
No I have not take the Post Builder class, I would like to though.
I have looked at those tips before but I will look again.
Thank you
John
