Two object attribute reference attached
I've in the title block cell this text <WRef1*0@RevLet><WRef2*0@Rev>.
The PDM create the part attribute RevLet when the item increment the revision, so not always the attribute RevLet is generated and the title block doesn't show nothing olso if the Rev attribute is present with a value.
The sintax <WRef1*0@RevLetterale><WRef2*0@Revisione> is incorrect ?
Can I merge with some extra string or I need to add a space between the two string ?
Thank you...
Using NX 8 and TC9.1
RE: Two object attribute reference attached
Omit the Ref1*0 and Ref2*0 (as they are assigned by NX (and probably to different attributes, e.g. RevLet and Rev)).
The <W@RevLetterale><W@Revisione> syntax should work.If the attributes exist NX will convert to add the Refn*0 notation.
HTH, Joe
