Pattern Feature - default Simple instead of Variational
Hi all,
do I have a chance to set Simple as default for the Pattern Method ?
(Rel. 8.0)
Wolfgang
(Rel. 8.0)
Wolfgang
RE: Pattern Feature - default Simple instead of Variational
I am not aware of the setting for this but you may either utilize a Role (with saved dialog memory)
otherwise in the same session once the SIMPLE setting is used once it is remembered afterwards (untill you change it back).
Thanks and Best Regards
Kapil Sharma
may you breakdown the dialog to your company needs.
regards
Thanks a lot
