Reading spline points from a file
thread561-344906: NX 8.5 spline though point (from file)
I understand, sort of, John Baker's reasoning for removing the old method of inserting a spline by reading a set of points from a file, but my entry level CAD students still need to do it. We had been creating airfoil profiles from ascii *.dat files with the old method. It was simple, quick and productive, and it showed off NX very well. Given that it's no longer there is there any work-around that is still easy for newcomers to do?
RE: Reading spline points from a file
Frank Swinkels
i have worked for some of my customers who are into turbine blade mfg. Agreed that using the spline (by reading text files) came a s quite handy option but we used knowledge fusion for doing the same just to ensure that associativity with the excel/notepad (we normally used excel) formats is maintained (i know it may not be a requirement as such but still it was a requirement from the customer end and besides this we can tweek the code to do some more customizations too).
Thanks and Best Regards
Kapil Sharma
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
I do understand that you folks make such decisions on very solid grounds, and that no matter what you do, someone will be affected in a way that might make them unhappy. Based on the incredible product you have, I'm fine with your judgment.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
