Supercritical nuclear power plants
Coal plants have used supercritical heaters for along time, and now even "ultra-supercritical" coal power plants are in operation.
Nuclear power plants are stuck at the theoretical stage for supercritical power? Whats the bottleneck?
RE: Supercritical nuclear power plants
Conservative thought about steam heat transfer processes at the most limiting point.
Length of piping (number of pipes and pipe penetrations going in and out of the primary systems and through the primary pressure boundaries.
Coal and gas-fired boilers blow extremely hot air and combustion gases past the saturated steam to gain their superheat, right?
You take the saturated steam from the boiler piping at the end of the conventional runs, run it back to the front of the boiler in new rows of pipe being hit directly by the hottest of the boiler gases as they leave the burning area.
So, in a nuke, where are you getting the the "extra" heat? The core, right?
So, you need to run hundreds of pipe (or regroup all of your existing pipes into a single one again) back into the the hottest part of the core (where you are trying to control the nuclear reaction by modulating the water fraction, fuel fractions as they change, and control rod fractions, poison fractions as the fuel burns up, and the "contamination" of the various components as fuel becomes replaced by nuclear fission products. Now into that, you are introducing a varying steam+water mix of pipes and pipe materials - none of which are fuel - and all of which vary in density and nuclear cross-section with temperature.
It makes your nuclear control more difficult, your metalurgy more difficult, your primary containment system more difficult. A few plants - I don't recall which, DID try to even use conventional burners + superheaters to reheat the saturated water post-steam generator, but that didn't last long. Too much cost for too little benefit.
All of these problems could be solved, have been looked at before in various ways, but the simple, solid design of "leave it as is" weighs out. You have to be able to sell your design across the public desks of local and state politicians, to the local public.
i must respectfully disagree with this:
"Now into that, you are introducing a varying steam+water mix of pipes and pipe materials - none of which are fuel - and all of which vary in density and nuclear cross-section with temperature."
a supercritical fluid isnt a mix of stteam and water, its a homogenous supercritical fluid, that is the definition of supercritical.
but to cut to the chase, i agree with this:
"It makes your nuclear control more difficult, your metalurgy more difficult, your primary containment system more difficult. ......Too much cost for too little benefit. All of these problems could be solved, have been looked at before in various ways, but the simple, solid design of "leave it as is" weighs out. You have to be able to sell your design across the public desks of local and state politicians, to the local public. "
and that is the answer. thank you racookpe1978 :)
Modern coal fired USC ultrasupercritical units also use multi pass designs, basically :
economizer==>lower evapaporator==> upper evaporator==>primary superheater==>secondary superheater(s), with full mix headers between all circuits, except the 2 furnace evaporator circuits have a partial mix header.
Latest Gen IV USC designs also have a less-than-credible design configuration, based on the false assumption of equal characteristics of each channel . The truth is each channel has widely varying charcteristics ( heat generation, fluid friction , inlet and outlet header flow unbalance)- I would think twice before buying a house next to one of those demonstration plants.
"Whom the gods would destroy, they first make mad "
*USA and USSR have tried and abandoned liquid sodium. Soviet Alpha Fast Attack subs with a sodium-cooled reactor were so fast that the US & UK had to develop faster torpedos to catch them. But the reactor suite problems outweighed even this enormous speed/power advantage.
One of Rickover's few technical failures. He had many other problems, but was usually very good on applying technology safely and reliably when facing thousands of new problems with little experience.
One proven method is to use a separately fired superheater/reheater , and today's low cost of natural gas would trend in the direction of such a hybrid cycle
Anther method tied to the LMFBR is to use supercritical CO2 as the secondary working fluid. The CO2 does not have the same reaction hazards as would H20 during a HX leak, and the critical temperature of CO2 is so low that metalurgical overheat issues associated with traversing the psuedo-critical point are not nearly as bad as with H2O.
That said, please educate me.
1. How do the liquid metal specialists (iron foundries, iron and magnesium and titanium or aluminum casting sites where air (oxygen) contamination is dangerous or destructively reactive, etc.) manage shutdowns and startups? How do they handle catastrophic (sudden or unexpected) rapid shutdowns or "black island" loss of power incidents without losing their facilities?
2. When we were pouring melted aluminum, if the heat were lost, the single "pot" would cool and solidify of course, but could be remelted with only lost time or that one bad mold as a penalty. But how do you "remelt" a complex piping arrangement with pumps, sensors, backflow spots and multiple flowpaths inside and around the core of a very radioactive source?
3. In a liquid metal reactor, do they anticipate electrically "re-melting" the core and pipes and pumps and heat exchangers first after every shutdown? How do they propose maintenance in piping or heat exchangers or valves when the valve interior is going to be coated with "solid" debris and sludge after shutdown even if "drained" first?
http://en.wikipedia.org/wiki/LMFBR#Fast_breeder_re...
it says, "As of 2006, all large-scale fast breeder reactor (FBR) power stations have been liquid metal fast breeder reactors (LMFBR) cooled by liquid sodium." so liquid sodium cooling is state of the art - in practice not theory. but if this is wrong pls lmk. ok?
Basically, it is like 100-mile/gallon carbureators. Everybody wants to get one to work, but nobody has accomplished it yet. It might be do-able, but it appears to need either an engineering or a materials-of-construction breakthrough.
Why would you use burners for reheating when you can reheat using live steam? Superheating is of course a different chapter.
Mentioned above: If you take "live steam" off of the top of a BWR, then you need to go back into the core (through the core) to heat it higher. that requires hundreds of (potentially leaking!) penetration - each very expensively and very slowly welded individually - to get the steam back through the core and into the pressure vessel and into the reactor containment.
Can't afford it; Too risky; no effective payback for little gain.
If you are talking about superheating the live steam then for sure this seem like a VERY challenging task in a NPP.
This has been proven to be a safe design, but it also limits the steam cycle to one based on the saturated steam conditions in the primary circuit, roughly 690 F.
To achieve better steam cycle heat rate ( or efficiency)one needs to raise the final steam temperature entering the steam turbine inlet far above 690 F. Currently installed commercial fossil fired steam cycles are operating now at 1100 F, with proposals to as high as 1300 F. Most are single reheat cycles, but further efficiency improvements are available at double reheat using the newly Elsom-patented " master cycle" ( where the HP feedwater extractions are not sourced from the power turbine) .
Higher steam temperatures can be had by use of a separately fired superheater ( as at indian point #1). If one substituted a supercritical water flow for the lower pressure boiling water flow used at conventional reactors, the "circulation ratio" would need to be reduced to 1:1( ie it beconmes a "once thru unit"), which means it becomes extraordicanlrily important to ensure the "worst channel" does not become oveheated - thus the need to calacualte the thranl hydraulic sensistivity characteristic S of the circuit- and a single pass circuit is not feasible.
Want to know the do's and don'ts of Eng-Tips? Read FAQ731-376: Eng-Tips.com Forum Policies.
English not your native language? Looking for some help in getting your question across to others or understanding their answers? Go to forum1529: Translation Assistance for Engineers.
