Head Studs vs. Bolts
I understand that head studs are generally prefered to head bolts because they "eliminate" the torsional force experienced by the bolt and thus provide a more accuracte clamping force...
How does this work? Isn't the idea behind this that the nut "slips" on the threads thus "eliminating" the torsional force? From a FBD perspective the force holding the nut from coming loose is the (torsional) friction force between the threads, generated from the coefficient of friction and the (axial) normal force between those threads. Thus, my first point to make is that the torsional force is definitely not "eliminated" as a lot of people state. My QUESTION regarding this is:
How is the bolt any different than the stud if this is the case? I understand we add a threaded connection when a stud is used, but we already have a threaded connection with the bolt... why is two better than one (if that is the argument). In essence, this reduction of torsional force is due to the interface of a threaded connection. Thus, this same reduction must still be taking place at the interface of the bolt and the threaded hole in the engine block... How does adding a second threaded connection (nut and stud) reduce the torsional force on the stud so substantially as compared to the bolt? I feel like I am missing something simple mathematically but I just can't seem to figure it out.
I also read that studs are better for wear in the sense that repeated disassembly/assembly results in wearing the threads on the stud and not in the block... I don't understand the reasoning behind this.
RE: Head Studs vs. Bolts
Elsewise, it's a religious issue.
Mike Halloran
Pembroke Pines, FL, USA
No sliding while supporting big load = no wear
Sorry, Tmoose I don't know what you mean by no sliding while supporting big load.
with a stud properly installed (i.e. not bottomed out) i think a smaller amount of the stud sees the torsion you get from a bolt which twists about its "whole length"
H
www.tynevalleyplastics.co.uk
It's ok to soar like an eagle, but weasels don't get sucked into jet engines.
An engine that gets torn down on a regular basis (ie. a race engine) will usually be better off with studs/nuts, since the screw threads that will experience wear or damage are on components that are easy to replace. Production engines almost always use bolts because they only require producing a single threaded connection, which reduces cost. And as others noted, most production engines now use torque-to-yield cylinder head fasteners which can be made from lower cost materials. It is probably easier for automated machines to install/tighten torque-to-yield bolts as opposed to studs/nuts.
For cylinder head fasteners, both bolts and studs/nuts can give excellent results if they are designed, manufactured and installed properly. And both types are subject to torsional strain in the fastener body at installation due to prevailing torque in the threads, especially with long grip lengths. So the best choice would depend upon the particular application.
Terry
The bolt threads are still sliding along and gainst the threads in the block just as the full clamping load of 7000 lbs is achieved.
When a stud is used the threads in the block don't slide.
( some would argue fervently that when the block is threaded they are head screws, not head bolts )
I see. They don't slide during subsequent disassembly/assembly of the cylinder head so there is no wear of those important threaded connections. However, I would make the point that they do slide (and thus plastically deform) during the first installation.
Also Tmoose, I would agree that they are technically machine screws and not bolts.
RacinNdrummin and inline6,
I think the point about the finer thread on the nutted end of the head stud is the key to explaining how the torsional force is reduced and thus more accurate clamping force is acheived with head studs. IT'S THE CRUX!
Thanks everyone for your input.
Norm
Parallel grind ends screws or studs.
Install screws or studs no load and check free length using ultrasonics.
Tighten using ultrasonic checking for length required to produce correct clamp load.
Keeping track of required torque which will blow you away.
I have seen 7/16 GM SBC head screws long ones take 48 lb/ft and 85 lb/ft to reach the same clamp load.
That is why you see TTY (use once) and TTA (reuse OK) fasteners being used more and more as they offer less clamp load scatter.
P-51 Mustang WWII Fighter plane V-12 crankshaft main studs were TTA.
Old School Not So Bad
Mike Caruso
www.aera.org
Is that variance seen while keeping as many variables as similar as possible or is that variance seen with big changes to variables?
Main ones I can think of are brand of screw or stud, brand and hardness of washer used or even no washer used, lubrication used or even none at all etc?
Yes you are correct (Main ones I can think of are brand of screw or stud, brand and hardness of washer used or even no washer used, lubrication used or even none at all etc?)
The testing I did they was Factory OEM GM NEW head bolts. Lube, Material and washers being stamped or ground.
EP Grease, ARP lube, Anti-seize all can and do have different fricton reductions when using a toruqe wrench.
Nothing is easy as it seems, just screw the heads onto the engine.
TTY, TTA make it easier and better for mass production.
Mike Caruso
www.aera.org
Yes the OEM have wonderful TTY tightening machines on the assembly line. I know Ford has since the head fastener change in 1992.5 on the Ford 5.0L H.O. engines and I am sure there are many more.
Bottom line......The OEM knew by reducing scatter of fastener clamp load they would pay out less warranty moneys.
Mike Caruso
www.aera.org
A disadvantage I have found with bolts is that I am always worried that he various passages in the head gasket will line up perfectly - it is easy to disturb the head gasket when placing the head over the engine. These days I use a few "temporary" studs for alignment when putting the head on a "bolt" engine.
Check out this site very good easy for all to understand. Nose around as he has layer after layer great information. http://www.boltscience.com/
No I have nothing to do with him or the site.
Mike
Mike Caruso
www.aera.org
highly intrigued by the info coming through on this thread. Mike please clarify a small point do I understand correctly that the main bolts/studs on the WW2 Merlin/mustang, were tightened to a "Torque to Angle" basis I am assuming TTY is torque to yield and TTA is torque to angle.
In the late 60,s I was fortunate enough to assemble both Repco F1 engines and then went on to Cosworth F1 engines, and following that quite a stint building SBC and Ford 350 to a very similar Imsa spec, what is intriguing is all values were in FT/Lbs but I am staggered to hear that TTA was used way back in the 1940 or before, or have I got it wrong. Comments appreciated,
with thanks Golfpin
Yes sir TTA was used on the mains. In the GM service manual it showed you have to check the crankshaft main housing bore for size. Next GM supplied a Ground Bar or Tube that you slipped into the block. Next installed and tightened the caps in place. Now the test is if the bar could be rotated by hand the block was ok for true.
I lost about 30 years of paper work in a flood of sewer water in my house or I would have scanned the pages for everyone.
Mike
Mike Caruso
www.aera.org
Mike Caruso
www.aera.org
Mike thanks for the reply, but am still a little puzzled. Your answer stops short at the mains, referring to the Merlin engine? Because the next sentence refers to the GM practice of using a test bar, does that mean the big ends on the Merlin were not tightened on a TTA basis?
The mandrel type of test is very familiar to me, it was used by quite a few, if not all the major manufacturers, even made my own.
Now here is my true dilemma, quite some years ago when assembling SBC,s the rule for big ends was torque to 65 f/t lbs measure the stretch , if not [.005] 5 thou increase torque to a max of 75 ft/lbs. If the bolt does not achieve the required stretch or exceeded it, within the 65-75 ft lb range DESTROY bolt and use another one, this was clearly before the era of ARP. Does this mean that the quality of the big end bolt was that much better than the current factory bolts? As pointed out by Tmoose most of the changes seem to be money/cost driven. Hope that this is not too far from the bolt vs stud issue but info begets questions not so?
Thanks Golfpin.
I did not say Merlin I think you did.
P-51 Mustang used the GM Allision V12 that's why you are asking about GM my GM reference.
The tube or bar is in place of the crankshaft with-out bearings to check for true.
Bad screws/bolts are just that screws/bad bolts.
You can also us ultrasonics to check free lenght and tightened (stretch)length.
The cost for changing to TTY was pennies for Ford to reduce monies paid out to replace the leaking head gaskets.
Ford already had automated machines head screws/bolts just needed to be reprogramed for TTY steps.
Hope that helps.
Mike
Mike Caruso
www.aera.org
thank you for your patience and the courtesy of your replies, was not aware that Allison was built by GM, thks again
Golfpin.
No Problem sooooo many things I don't know Yet Ha.
Anytime,
Mike
Mike Caruso
www.aera.org
"Schiefgehen will, was schiefgehen kann" - das Murphygesetz
Mike Caruso
www.aera.org
Air-Cooled vs Liquid Cooled Aircraft
