Customize QuickPick
Customize QuickPick
Hi friends
I have a question? is possible customize the "QuickPick"?
Actually I have using NX9
Thanks for your contribution
Tom
Tom
NX 9.0 WINDOWS 8 ENTERPRISE
RE: Customize QuickPick
BTW, here's a 'tip' for you. Go into Selection Preferences and toggle OFF the 'QuickPick on Delay' option. This way you will ONLY see the QuickPick dialog when YOU want to see it, not when the system times-out based on the QuickPick 'Delay' setting. All you have to do to get the QuickPick dialog to appear is place the cursor over what you you wish to select and hold down MB1 for approximately 1/2 second. This way you will not have to either wait for QucikPick to activate or find that it's activating way too fast or too often. Anyway, give it a try I think you will see that life is much simpler with QuickPick only coming-up when you want it to.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
