How to define a spring "Body-Ground" with 3 different stiffnesses ?
Hi to all,
Does anyone could tell me how to define a spring "Body-Ground" with 3 different stiffnesses (X,Y,Z) in Ansys Workbench 145 ?.
The only option I´ve found is the spring with longitudinal stiffness..
Thanks in advance !
RE: How to define a spring "Body-Ground" with 3 different stiffnesses ?
use 1 spring for each direction (PITA) or use a bush joint (also a bit of a PITA)
probably an APDL command might do the same but i avoid doing commands if i can work around it.
