what makes fiber stick together??
Hello All,
I am currently working for a company that processes coir (coconut) fiber. The processed fiber is used to make coir pads, geotextile material and several other products. My duties as a design engineer is to improve our processes and machines to meet the stringent quality standards demanded by the current market.
Since there is very little research data available on the internet and outside about the nature of coconut fiber, I am trying to get a feel for the physical characteristics by looking at other kinds of fiber such as flax, cotton and hemp.
My question is, what sort of mechanisms are associated with fiber sticking together without seperation?? Is it static electricity or just the surface texture or some other factor/factors? Also what are some of the methods used for fiber separation? The only method that has looked halfway effective (for coir) has been vibration of a fiber clump until individual fibers start falling away. But if there are any other more effective standard techniques I would appreciate the enlightenment. Thank you in advance for any input.
Cheers,
Asanga
Cheers,
Asanga
RE: what makes fiber stick together??
Thank you for the idea, the only problem with washing is that Coconut fibers absorb a lot of water. However its good to know that static electric charging can cause significant change in fiber adhering qualities. can you tell me what other mechanisms that hold the fiber together.
Thanks again,
Asanga
