using 'Through curves' for surface modelling
Hi all,
Am a basic user of NX and would appreciate any suggestions as to complete the surface modelling in the attachement. The curves were extracted from cloud points.
thanks
thanks
RE: using 'Through curves' for surface modelling
www.nxjournaling.com
but any suggestions on how to complete the shape?
In general, "all" surfaces are four sided and in the ideal world rectangular. I the real world the rectangularity almost never happens.
Since surfacing is a form of approximation of a desired shape, maybe you need to create some curves that you can use to define the missing surfaces.
A surface cannot guess the shape it should have, you need to guide it into that shape with some curves.
Tomas
