Archimedes screw power generator
I was reading about a couple of companies, that are making ac power generator systems.
They use an Archimedes screw with water running through it, a gearbox and a generator, for hydroelectric power generation. I like the concept, it makes sense to me. My question for you guys is this, if I had a large screw conveyor and its associated assemblies, trough and gearbox, do you think the standard dodge torque arm gearbox, could handle the input from the screw to drive a 100kw generator? I have not found the torque requirements for the generator yet. I haven't had time.
Better lives through fluid power.
RE: Archimedes screw power generator
A screw conveyor works best for slow movement of very stiff fluids (high viscosity) or grains or asphalt or peanut butter or grease. Water is too hard to seal around all of the many feet of sealing surface between the screw as it rotates and the pipe. Conventional waterwheels or water turbines are better for converting "down" motion (any vertical displacement of water) into electric motion (high speed rapidly moving magnets needing close tolerances).
Unlike air, where ducted propellers have been tried many times and have failed as many times, ducted water (ship) propellers are a little better, but still rarely are commercially successful. Inside pumps and turbines, ducted flow has ALWAYS proved more efficient than open flow.
What you will find, if you begin exceeding the resistance of the screw over longer and longer screws that try to turn a generator, is that the water will simply begin spiraling around the screw inside the pipe casing, not turning it the screw. You have to keep reversing the flow -> as in turbine engines and compressors where there is a fixed diaphragm of blades, a rotating stage, a fixed diaphragm, a rotating stage, etc.
Without checking and from memory would suggest efficiency of a well designed and installed unit being used as a pump would be 70% or so. Plus if it's the only way it can be done, then that becomes 100% compared to other methods which don't work.
This is potentially very efficient, as is a waterwheel. The problem becomes that you have a large heavy piece of equipment generating a small amount of power. If you can funnel the flow, and use a small fast-moving propeller-type turbine, and get similar efficiency, you have a much cheaper piece of equipment, and that seems to be the common procedure.
