Electronic PE Seal and Signature
How do obtain an electronic PE stamp and signature that can be use on PDF documents? What is the best way to do this?
RE: Electronic PE Seal and Signature
A lot of states allow a reduced size to be used.
I don't know what it matters though as no one can ever read my signature.
Mike McCann
MMC Engineering
BA
Mike McCann
MMC Engineering
Adobe PDF(full version) can do this; however, not all states accept only the Adobe encryption scheme. Others require a commercial encryption signature that can be quite expensive per document.
I can take my scanned seal and use it to create a letterhead which I then apply to the drawing sheets as they're printed to the driver. Each subsequent print job is added to the pdf and they all have the same seal as the overlay. The compiled file can then be saved with encryption, including a password if you want, to disallow changes or copying from the document.
(I also use it for correspondence with my actual letterhead and as a way to scan sketches and print them to to pdf with a letter-sized title block or calc sheet.)
