Divide a projected curve ?
Hi.
How can I apply "divide curve" to a curve created with "project curve"? (while working on a sketch).
For some unknown reason it seems it doesn't allow me to select that curve.
regards
regards
RE: Divide a projected curve ?
To my knowledge it wont work inside sketcher env. but could you please share the workflow you wish to follow (what exact output is required)
Best Regards
Kapil
I'm just speaking in general.
For example I've created this simple example.
I would like to divide the circle in multiple segments defined by the intersection with the straight lines.
Or even the opposite, divide the straight lines with the circle.
I can't do it within the sketcher environment nor outside it.
http://files.engineering.com/getfile.aspx?folder=c...
The divide curve works in the NX8.5 sketcher. ( NX8.0 ?) - NX6 and NX7.5 cannot divide sketch curves.
Many small steps makes a mature system ...
Tomas
Have you tried Edit - Trim Recipe Curve?
- Start with a partfile containing your Explicit Curve (the one outside the sketch).
- Create a Datum_Coordinate_System and choose the X/Y Plane to sketch on, using the Horizontal Axis as the Horizontal Reference.
- Project the Curve into the Sketch.
- Create a Line in the sketch anchored at the Origin of the Datum_CSYS and at an Angle (dimension) to the Horizontal Axis of the Datum Coordinate System. Ensure this Line intersects with the Projected Curve in your sketch.
- Trim the Curve using the Line as a Boundary. Identify which portion of the Projected Curve you wish to Keep or Discard.
- Project the Curve a second time and Trim that using the Same Boundary Line identifying which (alternative) side of the Boundary you wish to Keep or Discard.
You now have a SKETCH containing Two (connected) Trimmed Curves and a Boundary Line.- Finish the Sketch
- Suppress the Sketch Feature and Hide the original Curve.
- Unsuppress the Sketch Feature, so that you can see only the sketch.
- Try Extruding a Single Curve
- Try modifying the Angle to see how that affects the Extrusion.
Hope this helps?NXHerbie
NX7.5
Toost,
I created it quickly in a computer at work with NX6 but you can explain the divide curve for NX8.5 too, I can do it tomorrow in a different seat.
NXherbie,
That was similar to what I was doing, but I was looking for something simpler.
Regards.
But , since you asked me to explain, i now tried to divide / select the projected lines, and, no.
I guess that since the curves are sketch objects it's slightly more difficult to divide things than outside the sketcher since they should keep their associativity and then by the divide operation suddenly become multiple objects with associativity and potential constraints etc.
Tomas
Geoff
