Expression in tabula note cells
I've a tabular note where there are cells that contains the external diameter value and the wire diameter value.
The inside diameter is the external diameter - 2* wire diameter.
It's possible to add this relation between cells ?
The scope is transform the tabular note in title block and after populate only some cells and the others autoadjust her values.
Thank you...
Using NX 8 and TC9.1
RE: Expression in tabula note cells
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Thank you...
