Diameter and Radial Dimension Preference
I'm working for a German company which has preferences set up in the drawing upon creation of a new drawing (must be in the drawing format).
What I'm looking to do is to eventually create a macro that will set up the drawings in the manner which I prefer to see things. I have been able to override most every setting except for the diameter/radial dimensions. The default does not have a stub come off the dimension line. Basically, it just comes straight off the center of the radius/diameter as shown here:
http://files.engineering.com/getfile.aspx?folder=a...
But, in my annotation preferences it shows that it's supposed to be 5mm long. I also noticed that the menu button is grayed out (the one right below the "Line/Arrow" button shown in the image linked below
http://files.engineering.com/getfile.aspx?folder=2...
Any suggestion how to fix that issue?
Also, on my dimensions any horizontal dimension has the text aligned horizontally, vertical dimensions text aligns vertically. That's annoying too. Want to try to fix that as well. (See this image)
http://files.engineering.com/getfile.aspx?folder=b...
RE: Diameter and Radial Dimension Preference
www.nxjournaling.com
