UDF variables limits
Hello
I'm a new in this forum, so please be patient.
I'll try put variables for minimum range in UDF Wizard.
I've defined variable "HP_MIN" in expressions and I want use this like minimum range for "HP" into UDF.
Maximum I want have constantly (1600).
Thanks you for any anserws.
NX 8.5
Best regards
Sebastian B.
RE: UDF variables limits
Hi Sebastian,
You can still copy and paste the expression name in the range but the issue is that it will be remembered only once (first time).
Since i assume that the expression you are trying to select in the range value is not associated with any feature so it will not even appear in the UDG dialog.
Experts may have some solution to it i guess but i would rather use it as a reuse member if possible.
Thanks and Best Regards
Kapil Sharma
