Etabs Error run analysis
To all Etabs master, any body encounter this message in the run analysis: NEGATIVE JACOBIAN ENCOUNTERED. Please tell me hiw to solve this issue thanks.
Red Flag
this post
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Etabs Error run analysis
I am not an ETABs user, so I dont know the debugging process per se, but if you can try to view the mesh, or if it tells you what element is the problem, thats a good place to start. if you can adjust the nodal tolerance in mesh settings that may also help.
