Calculating Blower Power Requirements
Could someone let me know the equations that can be used to calculate,
the temperature rise in a high-speed turbo blower if;
1. Inlet pressure and temperature
2. Outlet pressure
are known.
the power requirement for a high-speed turbo blower if;
1. air mass flow rate
2. inlet and discharge pressures
are known.
Thanks in advance.
RE: Calculating Blower Power Requirements
Do a search for fan affinity laws.
The power required to compress a given volume of air in a given time period is the same for any fan, blower or compressor working with air, ideal gases etc...
Power to heat air is just a function of the specific heat capacity of the air, the volume and the change in temperature.
Simples!!!
HPost CEng MIMechE
