High thermal expansion at "normal" outdoor temperatures
I'm looking for a material with a high thermal expansion rate in the temperatur range of -20 to 30 celsius.
My challenge is to find a material type that can be made into a band/"rope".
Anyone with a good suggestion?
W
W
RE: High thermal expansion at "normal" outdoor temperatures
What I'm looking for is materials that have the highest thermal expansion rate in the temp range of -20 and 30 degrees celsius, which is also formable and can be used to create a band.
W
