Anhydrous Ammonia Cylinder storage
Hi all. My plant have a anhyrous ammonia storage tank and we vaporise to gas via a vaporiser. I was wonder if it is possible to replace with cylinder storage instead as our vaporizer (both) are having issues. The flow rate required per hour require is 100kg/h.
RE: Anhydrous Ammonia Cylinder storage
Good luck,
Latexman
Technically, the glass is always full - 1/2 air and 1/2 water.
i think of ammonia as having relatively "high" vapor pressure for a given ambient temperature. for instance, ~50 psig at 32°F and ~ 197 psig at 100°F.
if you are in a warm climate (e.g., southern florida), you may not need a vaporizer to deliver ammonia at 55 psig. basically, you will gain enough energy through the pressure vessel wall to keep pressure on the system.
if you are Canada and operating in the winter and need 100 psig, you definately need a "heater or vaporizer."
typically i have seen more of a "heater" design where you keep the pressure in the tank by using a "side-arm" heater/vaporizer where you have liquid flow from the bottom of the tank going to the heat source and a vapor balance line back to the top of the tank. i would not recommend a liquid line feeding a separate vaporizer unit if you could avoid it.
