Crosshole Sonic Logging Interpretation
hi all,
i have problem with CSL test on test-pile with instrumented pile. but CSL test in this test pile indicated that pile has defect from depth 0-7 m (debonding)at all pair tube, and for tube pair 1-2 and 2-3 at depth 8-13.6 m (with remark 70% velocity reduction).
can anyone give technical comment regarding this CSL test, is it possible to conduct static loading test until load 250%?
thanks in advanced.
thanks in advanced.
M.A.
RE: Crosshole Sonic Logging Interpretation
thanks for comment, i have been discuss with owner to conduct PIT test to makesure the pile integrity have defect or not, since as second opinion from our geotechnical professional this test pile can't to conduct static loading test with load until 250%, because possible the pile will have large settlement (25 mm until 40 mm) due to defect at depth 8-13.6 m. he is very sure that at depth 8-13.6 m is the defect since CSL test indicate velocity reduction its not because debonding.
fyi : this tube using PVC tube, with 3 tube. this pile also instrumented pile with vibrating wire strain gauge. if we can not do SLT, our cost for instrumented pile will useless. and as writen at drilling record also reported that while pooring concrete have been waiting for 4 hours, from 4th Truck Mixer to 5th Truck Mixer.
please advice, if there any treatment so this test pile instrumented not useless.
thanks,
M.A.
Repairing such defects is not an easy task and success is not guaranteed. You must drill holes to reach the defects, wash the cavities and grout them. I would advise you to construct another test pile but before doing it check and improve your concrete procédures.
for Thermal Test is it worth than CSL? what is the limitation of both of the test?
M.A.
we have been conduct axial compression static loading test on this pile without treatment, and the maximum settlement at 250% Design Load only about 18 mm (thats mean this pile actualy safe).
but now we still have the question :
1. what is the really problem of CSL and PIT Test result that both of NDT Test on this pile that indicating have defect, but actualy we conducted SLT 250% of Design Load, Max. Settlement still acceptable in local code (for Diameter 100 cm, max. settlement < 4% x D)? is the NDT Test not acceptable or maybe there is anomaly?
M.A.
Congratulations on a successful test.
