Conduits for power cables
Our project engineering spec requires rigid steel conduits for exposed power cables, liquid tight flexible metal conduits at cable connections at motor driven equipment for both outdoor and indoor use. Is there any particular section in NEC that mandates this and can somebody share that applicable section?
RE: Conduits for power cables
There are possibly issues with mechanical damage.
If the project spec calls for rigid steel conduit then use rigid steel conduit.
If the project spec calls for rigid aluminum conduits then use rigid aluminum conduit.
If the spec calls for EMT and dry type flexible conduit then use EMT and dry type flex.
If the project calls for TECK cable then use tech cable.
If the project spec calls for tray cable then use tray cable.
The NEC allows several types of feeds to motors.
The project spec generally rules.
If the project spec appears to conflict with the NEC then submit an RFI (Request For Information). Then if an inspector rules that an installation is a code violation you have protected your ASSets.
DTFP (Don't Fight The Problem.)
Bill
"Why not the best?"
Jimmy Carter
What is your actual question?
However in a power station –where NEC is not a rule and the cost of electrical installation it is a very small percent of not-delivery power- the owner may require such an installation as more reliable one.
