Carbon Steel Railing
I am just trying to test a railing by the OSHA specifications. The railing is ASTM A53 grade A Sched 40 Carbon Steel. The railing is 6 feet long between posts and 42 inches high. The nominal weight is 2.72 lb/ft, yeild strength 30 ksi, tensile strength 48 ksi, and allowabale stress 22 ksi. The railing is supposed to be able to withold a 200 lb force in any direct except for up. Can someone help me figure out how to prove the the railing meets the specifications
