Asme IX welding
Asme IX welding
Hi could please advice …
If 60deg bevel and 1.6mm root length weld qualification by using asme ix can be used for 60deg bevel and 2mm root length weld.
is this root length is a essential variable as per asme ix.
My understanding of the standard is the bevel angle cannot be less than 10deg is the essential criteria.
RE: Asme IX welding
Bevel angle is not specified in the code and is left up to the fabricator to decide. Again, it must be addressed in some fashion on the WPS.
RE: Asme IX welding
So if i did the 1.6mm root length for qualification WPQ, can be used for a 2mm root length ?
RE: Asme IX welding
