Edit title block cells
I've a spring template drawing with title block like the pdf attached.
Now, some texts in the cells need to be modified.
Edit definition permite me only change the labeling.
If I remove the table from the title block to adjust the cells, after adding again the table in the title block, I lose all labeling customization ( hours and hours of work).
Solution ?
Solution ?
Thank you...
Using NX 8 and TC9.1
