Change annotation style in existing drawing
Is there a way to change ALL of the anotations in an existing drawing in one go? I have to change the character font and size.
RE: Change annotation style in existing drawing
Yes...
You can select them all and change the font and character size in the style menu...
Ronald van den Broek
Mechanical Engineer
Cad Environment Coordinator
Wärtsilä, Propulsion Services
NX8.5.2 / TC9.1.2
HPZ420 Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz, 32 Gb Win7 64B
Nvidea Quadro4000 2048MB DDR5
You can register a macro in this sequennce :
Click on the Edit Style icon
In the class selection mask, in the type filter, select annotations you want to change
Then click on select all
Change the annotations style using the load all default or changing single option.
Thank you...
Using NX 8 and TC9.1
Thanks, I will try this out!
