Slotted Holes & Eccentrically Loaded Bolt Group
I have an office debate I would love to hear opinions on:
Slotted holes may be used without being slip-critical if the load direction is perpendicular to the slot. Does that imply that the eccentrically loaded bolt group table 7-7 for 0 degrees is valid with slotted holes? (load is applied perp to the slots)
RE: Slotted Holes & Eccentrically Loaded Bolt Group
