Core and Cavity SW 2013
Please, if someone tries to make a core and cavity of this Part.
THANKS http://files.engineering.com/getfile.aspx?folder=d...
RE: Core and Cavity SW 2013
Chris
SolidWorks 13
ctopher's home
SolidWorks Legion
Your imported part geometry has errors.
Before you start creating parting line and parting surface, you must fix this first.
Need to modify some of the faces for negative draft. This gives a better split.
Certain face may be done with a manual split.
Hope this helps to create your split
Here is the exploded view of the core & cavity
can you upload stp files?
Have you tried to split and what's the problem you face?
If you post the work you did, someone could help you.
