Fire Damage
Fire Damage
A question for those of you who understand the consequences of steel and heat treated steel being exposed to fire. Starting on a new winter project of turning my old 2wd tow rig into a 4wd. The attached link is a direct fit for my truck, but I am concerned about the axles exposure to fire. Specially the heat treated parts such as the axle shafts, ring and pinion, and bearings. I am not overly worried about it, however, I would like a professional opinion in this area. Thanks in advance. Regards.
http://www.ebay.com/itm/99-00-F450-4x4-Front-Axle-...
RE: Fire Damage
Ford axles are hardly rare. I'd pass on that one and find one that hasn't been cooked.
RE: Fire Damage
RE: Fire Damage
At the end of it all, seems as though you are only buying a housing, axles, crown wheel - pinion and hubs.
RE: Fire Damage
Since it isn't then if the oil is still present I'd take a punt and say it hasn't got hot enough to ruin the hardening, but frankly a thousand bucks seems like a lot for this.
Cheers
Greg Locock
RE: Fire Damage
