Input field for tolerance/clearance
Hi all,
I have basic shaft/hole problem with contact. I have already solved it without clearance. Now I want to see the effects of ISO clearances like H7/e7 or H7/d7.
I know I can modify my geometry with cut etc. to achieve required clearance. But I wonder if there is an input field that I can easily enter the input like 0.356 mm.
Thanks!
Thanks!
