Routing Mechanical - 180deg rod bend
Hi.
First time poster here.
Im looking to make a 180deg bent rod and get the bend radius and rod length in drafting later.
It would also be nice if I could modify it later in Expressions.
I do have access to the Routing Mechanical add-on but Im lost as to how to do this.
Is there a tutorial or example .prt file anywhere to be found?
Specifically, Im trying to make this:
Rod diameter: Ø25mm
Bend radius: R635mm
Thanks in advance for any help.
RE: Routing Mechanical - 180deg rod bend
What version of NX are you using? Also, you mention Routing, but are you actually creating a Routed system or just contemplating using it since it can report length data?
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
