Rigid Beam Problem
Rigid Beam Problem
Hi all first post so hope you can help!
I am trying to model the effect of applying a force at one end of a rigid beam, on the displacement at the other end which in turn is connected to a piece of plate (representing a flat bar stiffener). The rigid beam is constrained at a point between the two ends so that is can only rotate.
So in theory, the force at end 1, should cause a rotation about a mid-point and therefore force a moment at end 2 onto the stiffener.
There may be a better way to model this but I am currently attempting to use an MPC184 element to model the rigid beam and the SHELL181 element to model the stiffener. I am also using non-linear analysis as advised by ANSYS for MPC184 elements.
At the moment there is no convergence of the solution and no deflection. I would hazard a guess at the fact that this is down to my knowledge (or lack of) about the MPC184 element.
So my question is, how can I setup a MPC184 element to be used in this way?
Thanks for the help!
