Through Curve Mesh From Point To Point in NX7.5
I often use the tips shown in the attached part to avoid singularity point in Through Curve Mesh starting with one point
I am looking for another method to create the surface in one step
Thanks in advance
Didier Psaltopoulos
http://www.psi-cad.com
RE: Through Curve Mesh From Point To Point in NX7.5
What's wrong with the original Surface 'Through Curve? Mesh'? It's perfectly valid. Those ends where you've selected 'points' are technically not singularities (trust me, if they were, NX would not have allowed the B-surface to be created).
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Hi John,
This example is very simple for explain the method. Maybe the Term "singularity' is too hard.
Two problems may occur
- machining along iso-parametric should give a wrong quality
- unable to apply thicken
Have you another method, maybe with styled sweep ?
Didier Psaltopoulos
