Terminating Oversized Cables
What's the proper way to terminate parallel conductors in a disconnect? The lugs would only except two wires that's one size smaller than the wires that exists.
A distribution block in a separate junction box just before the disconnect?
RE: Terminating Oversized Cables
Pin connectors such Hyplug can be used when wire is oversized for voltage drop.
Might you be able to us some connectors from here: http://www.polarisconnectors.com/
I would be interested in hearing if the disconnect switch manufacturer may have some additional suggestions.
