In the low 50s
In the low 50s
OK, I'm writing for a newsletter that goes to both America and Singapore. All of my references to temperature have to follow the format: 32°F (0°C)
I can't get around this by re-wording (the boss says so). I have to state that "...temperatures are in the low 50s."
How can I do the 50s reference to indicate that it's degrees F and add in the degrees C conversion?
Any help will be appreciated. I'm stuck and my brain is tired.
Best to you,
Goober Dave
Haven't see the forum policies? Do so now: Forum Policies
RE: In the low 50s
"...temperatures are in the low 50s.(°F) (~10-12°C)"
Good Luck
As a circle of light increases so does the circumference of darkness around it. - Albert Einstein
RE: In the low 50s
[ponder]
RE: In the low 50s
RE: In the low 50s
Quando Omni Flunkus Moritati
RE: In the low 50s
RE: In the low 50s
"...temperatures are in the low 50s (~10-12°C)."
"Simplicity is the ultimate sophistication." L. da Vinci
G. Coppola
RE: In the low 50s
I think I'm going with CajunCenturion's way, then see what the boss wants to do to create a mess out of it.
FeX32, your way looks nicer but I'd get my fanny kicked if I left out °F
TheTick, if I use Kelvin then I'd have to convert to Rankine, which makes me think of my old thermo class from 35 years ago, which makes me want to puke.
Thanks to ALL!
PS -- the boss is my wife
Best to you,
Goober Dave
RE: In the low 50s
LOL!
G. Coppola
RE: In the low 50s
You don't stand a chance.
Good Luck
RE: In the low 50s
- Steve
RE: In the low 50s
David Simpson, PE
MuleShoe Engineering
Law is the common force organized to act as an obstacle of injustice Frédéric Bastiat
RE: In the low 50s
According to http://en.wikipedia.org/wiki/Geography_of_Singapor..., the all-time record low for Singapore is 19.4°C (66.9°F) on 31 January 1934.
http://julianh72.blogspot.com
RE: In the low 50s
- Steve
RE: In the low 50s
Guess what? The boss agreed with CajunCenturion! I had a peaceful night.
Best to you,
Goober Dave
RE: In the low 50s
- Steve
RE: In the low 50s
"It's cold."
RE: In the low 50s
I guess I should have given context in my OP. The low 50s.(°F) (~10-12°C) occurred indoors in a building whose heating system was vastly undersized. It was a retrofit job and he didn't pay attention to the size of the existing boilers that got scrapped. The engineer looked up at the roof deck from underneath, saw metal, and
ASSUMED there was insulation above. He was too lazy to climb up the roof access ladder and look.
Turns out all that was on top of that metal deck was felt, tar, and bird poop. His E&O insurance paid heftily.
Best to you,
Goober Dave
RE: In the low 50s
Even "a bit nippy" needs regional / cultural context. In some places (in northern Europe, or Canada, for example
RE: In the low 50s
I had an English room mate whose mum told him over the phone that it was quite warm. When he asked her "How warm is it?" she replied "You can take your coat off".
RE: In the low 50s
RE: In the low 50s
At minus four degrees
A slow, deep, clear, cleansing breath
Makes frozen boogers
Best to you,
Goober Dave
RE: In the low 50s
RE: In the low 50s
Ben Loosli
RE: In the low 50s
David Simpson, PE
RE: In the low 50s
If you are offended by the things I say, imagine the stuff I hold back.
RE: In the low 50s
RE: In the low 50s
Living there as it went from fall to winter, the cold wasn't as noticeable as stepping off an airplane into that chill. That was christmas 1983 and my in-laws lived in Ririe, about 15 miles from Idaho Falls. Father-in-law was the school custodian and he still had to keep the coal fired furnaces going and the klinkers removed.
Ben Loosli
RE: In the low 50s
Best to you,
Goober Dave
RE: In the low 50s
unless the first number is in kelvin or some other obscure imperial unit, it will be a given for anyone american to understand its meaning. especially since the numbers in brackets already have the correct unit.
RE: In the low 50s
Best to you,
Goober Dave
RE: In the low 50s
old field guy
RE: In the low 50s
