Have the GAP symbols been removed from the Custom Symbol Library in NX 7.5 and onwards?
This in reference to thread561-305222: nx7.5 custom symbols, which I found while trying to see if the GAP symbols from the Custom Symbol Libraries (that I remember) from NX 6.0 and NX 7.0 have been removed during the transition to NX 7.5. I have reviewed the document, User_Guide_for_Custom_Symbol_Library_Installation_Tool_v2.1, located in XXX\NX7.5\UGII\symbol\install_tool, along with the two ZIP files that are located in that subdirectory - but I do not see the GAP125, GAP25, or GAP50 symbols. Have they been eliminated?
RE: Have the GAP symbols been removed from the Custom Symbol Library in NX 7.5 and onwards?
If I want to get the GAP symbols, I go to:
(drafting application) Insert -> Symbol -> user defined -> use symbols in => Current directory
To the best of my knowledge, the custom symbol stuff on my installation uses the out of the box defaults; your mileage may vary depending on your environment/customizations...
www.nxjournaling.com
Thanks for that answer cowski, because it appears that a quick trip to the I.T. Department is in order.
