Height of 132 Overhead Line
I am trying to design a lightning protection system for a building and want to claim protection by the earth wires of 132kV overhead lines above.
I've done the calcs to BS6651 and know the minimum height that the cables must be to give protection, however I don't know the actual cable height. The electricity company aren't that helpful and if I measure it with a theodolite I don't know what the maximum sag will be.
So, what is the minimum height allowable above a building of a 132kV overhead line?
What is the height above that of the earth cable? (they are double circuit towers (if that is the right term))
RE: Height of 132 Overhead Line
The utility might be able to provide profile of the line. I'm sure they would rather have you prove that the line provides the necessary shielding than have someone up on a roof anywhere near their line installing lightning rods.
