731 A/C pump curves
731 A/C pump curves
731 A/C pump curves
Help-I need th 731 A/C pump curves, Or comparison to the 3196
RE: 731 A/C pump curves
60Hz, I hope?
The whole set is 48MB. For some reason the upload isn't working. Will try later. Is there a size in particular that you're looking for?
The 731 is an ANSI design, so dimensionally they are interchangeable, but there are performance differences vs 3196.
