what is the difference 4130 weld inlay with SS316 or INC625
everyone,
Does anyone know what is the difference between adding inlay on 4130 body with SS316 or INC625?
so far i've seen these two inlays being used on wellhead equipment. but i dont know what's the advantage on one with respect to another. from what perspective we could say it's better.
thank you
thank you
RE: what is the difference 4130 weld inlay with SS316 or INC625
Advantage of 625: more corrosion resistant; does not require a different alloy for the first layer
The choice is down to what service the material is expected to see and whether 316 can tolerate it.
Steve Jones
Corrosion Management Consultant
http://www.linkedin.com/pub/8/83b/b04
All answers are personal opinions only and are in no way connected with any employer.
is there any specific parameter that become edge point on 316 which considered as a limit before we decide to use 625?
i guess its located at environment constraint in general???
regards
yudhi
Again, like SJones stated, depends on application which one would be better.
I'll dig deeper at NACE MR0175.....
really appreciate your reply.
regards
yudhi
