pdf export
pdf export
pdf export
When I export Sheet 1 to a pdf all of my dashed lines in the pdf appear like half inch long line with 1/4 inch spaces. Is there anyway to have the dashed line export to the same size as shown in the model view?
RE: pdf export
Yes, if you go to the LineStyle Control box and select "Other..." it will pull up a window. Make sure that the box marked "Scale based on sheet's units" is not checked. If you make any changes click on the activate button and then close the window.
RE: pdf export
Thanks! That fixed it.
