Multiple dimensions controlled by one independent variable in assembly
Hi all,
I'm looking to change multiple dimensions in a butterfly valve assembly by changing only one independent variable defined in one of the parts. For example, by changing the independent variable "ValveSize" to 2", 3", or 4", it will change the body height, arm length, shaft diameter, and the body diameter (across multiple part files in the assembly) to specific values. I know you can use inter-part references to set up relationships between two or so dimensions, but was wondering if there is an easier way to change multiple dimensions with one change in an independent variable.
RE: Multiple dimensions controlled by one independent variable in assembly
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
