Horsepower calculation. Bearing
When one using a bearing to drive a certain weight of material, do u just use the normal force multiply by the coefficent of friction and then use this force to figure out the torque?
I am using a bearing to drive some weight thru 6.67' distance, the bearing has pitch diameter of 3".
I obtained the following using the above info
FPM= 40
RPM= 51
Then here is the point I start getiing confused,
Force = coefficent of friction x weight
MY weight is 1500 lbs & coefficent of friction is 0.03
F = 1500 x 0.03 = 4.5 lbs
Then I use this force to figure out my torque
T = F x radius = 4.5 x .125 ft = .563 lb ft
and with that I figure horse power
HP = (.563 x 51)/ 5250 = .005 HP which seems really low to me...
Did I not do it correctly?
RE: Horsepower calculation. Bearing
Quando Omni Flunkus Moritati
You are neglecting inertia.
I use bearings to allow shafts to rotate with as low an amount of friction as possible....
TTFN
In some cases the torque of the seals is greater than the frictional
torque. The amount of clearance or whether it is preloaded causes
great variation as well. Is this a thrust or radial bearing, etc,
is it a roller, ball or pad bearing?
