how to perform consoildation,triaxial and permeability
I am interested to learn how to perform Triaxial,Permeability and Consolidation.Is there any traning courses or videos or any software where I can learn.
Mohammed A Sharief
RE: how to perform consoildation,triaxial and permeability
You also need to use the results of other tests with the ones you mentioned to understand the behaviour of the soil, both as it is before you carry out any construction and after completion of construction.
I'm not aware of any videos or training software, although I'm sure someone reading this will. If so, I would caution you to use it as refresher training, and not as your only training.
learn how to perform these tests.thanx for ur advise once again.
Mohammed A Sharief
Good luck.
ps...I do not work for MacTech (Law Engineering), I'm just familiar with the company.
