Hide the hidden line when export PDF
Hello all
When I export a model view to a PDF file, the hidden line always show(Please see the attached file). I try to change the options but can not hide the hidden line.
I'm working on NX7.5
Thanks for the help .
RE: Hide the hidden line when export PDF
Are you using : File - export - Pdf ?
There is a setting under Preferences - Visualization - Visual - (Edge display settings )- Infer Edge output, which should be ON.
( Which makes "what you see on screen becomes plotted / pdf" )
This setting is also a customer default, open the customer defaults and search for "infer edge" .
Tomas
