API 521 Vapor Discharge Capacity Equation
Hi all,
I'm in the process of sizing relief valves and I have a question about the equation for vapor discharge capacity (W) found in API RP 521. We have an old copy on file (1990) and the equation for vapor discharge (A-7) is a little complicated.
Looking through our Consolidated book, Crosby Engineering Handbook, and a bulletin put out by Leser, all show W = Q/latent heat of vaporization, which is much simpler. Is this equation in the newer versions of API 521, otherwise where can I find this equation in a standard?
Thanks!
Thanks!
RE: API 521 Vapor Discharge Capacity Equation
